Run water and water wetter! then install a elctric pump and those racing stats from Pat
you will have a hard time getting the truck up to temp![]()
what is the stock fluid they put in them Kevin?
Actually its a silicone based heat activated fluid. We used to change it in the Toyotas all the time. Never seen it on a cheby thoughYou can still buy it from toyota if you have the part number-I have 2 tubes of it sitting on our bench collecting dust.
Isn't it a viscous fluid of some sort Larry?
thats what the little bottle says.
Does it have an expiration date printed on it?
