Motor should be out this weekend. Excited to get started on it
I had the moroso deal plumbed into the exhaust. It was ok until this built motor. It has more blow by than the other motors. It was ok until started to see bigger boost. It would blow the dipstick out every time I went WOT.
How well does this work and where did you get the fitting? Is it better to us a one way check valve in this situation? I am looking at doing it to a buddys 13 cummins since i rerouted his CCV and he is complaning about the smell. If it works good, i may do it to mine.![]()
Here is what I am using instead of a pump. This Evac fittings weld into the exhaust. Vaccum is created to suck out crankcase pressures. It pulls up to 3 lbs of vacuum.
Why do you need two?Did you do one or two fittings? You need one for each bank.
