Engine build bundle packages.
ripmf666
15,123
14
47
Wentzville Mo
A few bundles we have can also change the bundles around to come with Finger Oval Pistons for +725.00 extra.
Carrillo rod bundle. 4,799.00 shipped + 725.00 using Finger oval Pistons.
http://creaturesofthenightperforman...-Carrillo-Rods-Pistons-Bearings-P3292161.aspx
Brian Crower Rod bundle. 4,100.00 shipped + 725.00 using Finger oval Pistons.
http://creaturesofthenightperforman...an-Crower-Rods-Pistons-Bearings-P5172414.aspx
Carrillo Rod bundle less piston kit. 3,150.00 shipped also do same bundle with Brian Crower rods for 2,650.00 shipped
Carrillo kit.
http://creaturesofthenightperforman...ul-Gasket-Set-H-Series-Bearings-P3579197.aspx
Brian Crower kit.
http://creaturesofthenightperforman...ul-Gasket-Set-H-Series-Bearings-P5429543.aspx
Mahle race cast bundle less rods. 2,570.00 shipped + 725.00 using Finger oval Pistons.
http://creaturesofthenightperforman...it-with-Mahle-Race-Cast-Pistons-P2372186.aspx
Mahle OEM bundle less rods. 2,150.00 shipped
http://creaturesofthenightperformance.com/Duramax-LB7LLYLBZLMM-Stock-Rebuild-Kit-P3604882.aspx
andy-stevenson
Jul 7, 2013
838
Don't think there's much. Last time I talked to Henry I believe he said he had a customer building a 1000hp motor with them.
I tried ordering a set of eBay and got jerked around for 3 weeks before I got a refund. Tried ordering a set from Henry but was told the same ^^^ 8 weeks out for a set.
Kind of hard to wait 2 months for a set because they don't keep any stock...
unionmax481
hot rodder
Aug 8, 2014
222
lebanon in
I got a ay from Henry i have my motor done just waiting on my transmission I'm running 100 overs and 472 I'll let you know how they are once i get some passes and tuneing done on the truck
ripmf666
15,123
14
47
Wentzville Mo
At the time you first asked for a set even on the first try of ordering forget what was wrong on think bank not releasing funds. There was 1 set ready to go out then. Most of the sets I have shipped have been in stock at Brian crower this is the first long wait time I have had getting sets.
ripmf666
15,123
14
47
Wentzville Mo
It's been a while since BC rods came out. Has there been any kind of feedback on these ?
Good or bad?
I think we have around 10 or so sets running around that we have sold in the bundles and alone. Other then a set that were miss cut or not finished around the small end of rod nothing bad back about them.
