When we originally released EFILive for Duramax nearly 3 years ago, AC functions were a problem. We identified that the major cause for this was people not using their own stock tune as the base for their modified tune.
If you are using a modified tune NOT based on your stock tune, we suggest you revert to your stock and build you tune again. Even if the OS's are the same, you'll find that the vehicle options will most likely be different which will cause this effect.
In the minds of EFILive this issue will be forever known as the "Guy Tripp Syndrome" :hug:
Cheers
Cindy
