Duramaxzak 2.6 pulling truck build
duramaxzak
Wanna be puller!
Nov 22, 2008
2,431
14
Minnesota
What else needs to be done when installing a body lift? Like extending wiring, etc.
Steering shaft longer, kit comes with spacer. I kind if depends what your running for intercooler and radiator. Body lift moves your whole core support up also. Mine trucks all custom intercooler, radiator and piping.
duramaxzak
Wanna be puller!
Nov 22, 2008
2,431
14
Minnesota
Finally got my Wagler intake installed. Turned out to be kind of a PITA! I had to slot the bolts holes with a die grinder to be able to get the mounting bolts in. Not sure because my heads have been milled to much or intake machining off.
duramaxzak
Wanna be puller!
Nov 22, 2008
2,431
14
Minnesota
Made a mount for the 12V hydraulic pump for the steering and brakes.
Oops, This one is upside down!
pornstar dancin
pornstar dancin
Oct 23, 2012
251
almond ny
Must be you have your heads shaved enough to make it a pain. My wagler intake dropped right in place real nice piece just hope its gains are enough to make it worth the $$
clrussell
pro-procrastinator
Sep 23, 2013
5,910
364
I'm sure you know its backwards..
Wonder if that makes a difference on the bolt hole alignment?
duramaxzak
Wanna be puller!
Nov 22, 2008
2,431
14
Minnesota
I purposely put on backwards for more room for 4" intercooler piping. The front to back alignment was fine, but it was like the intake needed to drop down in the valley of the heads more.
