Duramax in a '72 chevy truck????
kjp800
Aug 6, 2008
525
New Jersey
With 4wd, you either have to adapt the early transfercase to the transmission or use the new transfercase & swap the front axle for one with a dr. side differential.
On a 2wd, you just have to deal with the rear drive shaft.
Will the Allison fit under the body or does the body need to be modified? (firewall/floorboards) Maybe a small body lift? If I remember right, the PPE truck had to be modified for the trans to fit.
I'd like to keep the pass. side t-case and front axle, any suggestions on a transmission?
SmokeShow
6,818
Lawrenceburg, KY
To keep pass drop there's a few options:
- Nv4500 manual with a pass drop np205
- 4l85e with adaptor to run pass drop np205
- Allison with billet tailhousing from suncoast setup to mount any pass drop xcase you desire
- allison with an atlas xcase mated to it
There's probably more but those might be easiest. Wouldn't do big 4wd boosted launches or much sled pulling with an np205 n 14b in it. Both have been tested behind substantial diesel and neither are totally up to it with much success over time.
THEFERMANATOR
LEGALLY INSANE
Feb 16, 2009
3,890
ZEPHYRHILLS, FL
Member pussow at DP is using a 205 right hand drop behind an ALLISON in his 87 conversion. He made a custom spacer that chaged the drop a little and got it to clear he said.
