Duramax adjustable cam gear
S Phinney
4,008
Quncy, Fl
beat me to saying this. Im tired of seeing "new to the market" "made by us" "only available from ngm" and in reality hes a dickbag and makes nothing.
What about 90% plus of the others that have parts made by someone else but are marketed and sold as their own?
Sent from my XT1080 using Tapatalk
3,590
Mr Staab said over on Comp that NGM is simply one of their vendors. He also said that Danville will be selling these, among a few others and these gears should be available come Feb once tooling is all set up. Also said he has other products in the works. Great news!
diesel-max
Haisley Never heard of her
Oct 20, 2011
173
IN
That would be called private label, it would be nice to see a better marketing approach if that were his goal.
MarkBroviak
DMax Junkie
2,237
752
Danville Indiana
This is true but I like to fully test it before talking about it because like many other projects we have been involved with the product is never perfect first go around! I guess my approach doesn't sell as many parts up front but it makes for happier customers! I'll be the first to admit I'm not the best a marketing, usually let them speak for themselves on the track.
S Phinney
4,008
Quncy, Fl
Mark that is the best way to market. If you don't have the faith to use it yourself why sell it to others.
Dave c
Jul 7, 2013
294
I looked at it too, and read it differently. Wade started the project with NLM and kept it moving forward,(hence the "Wade lit a fire under my ass" comment) and gave ideas to make it better, such as the .5* increments for positive/accurate adjustments.
Not quite "just a dealer"
As for marketing and using it first before the sale, I'm sure it wouldent leave his shop or go to a customer unless it was 100%. Thats just the way he is. Reguardless if you like him or not, he builds some nice engines and is involved with some top shelf engine products!
adeso
wait, what?
May 30, 2011
1,569
Minot, ND
i know degreeing a camshaft properly in a BBC makes a huge difference in powerband, so yes i think its very beneficial to the guy who is trying to really dial in his setup
It matters more with big singles. Forced induction overcomes a lot. Not saying it won't help but not nearly as critical. It is how someone could put 900 HP to the wheels on a stock cam
Harbin_22
3,858
7
Southern Indiana
Wonder if someone is going to make a custom front cover so you don't have to buy a new front main seal every time you need to adjust the cam gear?
RPM Motorsports
smokinum
May 13, 2008
3,271
10
Central Valley Ca.
Since it would pretty much be a race application, might as well make it so a rev second CP3 can be run 1:1 off the valley CP3 gear, but on the outboard side of the cover ;)
S Phinney
4,008
Quncy, Fl
Degreeing a camshaft is for the purpose if making sure it is installed per the manufactures specs. Meaning there are variables that may make it out if sync for the intended purpose. Some guys then use the ability to change positions to move the power curve around. It is instrumental in making good combinations better. Usually you do not have a need to change it more than 4 degrees most if the time less. This is something that I have wanted to do for a while but wasn't available when it has been apart. I have always done it on my gasser builds.
F
Fahlin Racing
Guest
I am pretty excited about this product, only honing the engine's precision even more.
