Driver's side dipstick
The Neens
BFD
4,596
Monrovia, Ca.
Thanks to Mike & his guys for handling my dipstick...Looks much better...
whitetrash21
put on da damn helmet day
Apr 29, 2008
4,929
Vegas
As long as the dipstick is manipulated correctly.....no foul.
No better feeling than knowing your dipstick is in the correct hole.
4,950
i would have prefered to keep my dipstick in the much tighter side. It usually stays much warmer there when you have twins on top. you just have to have a little flex in there. :D
15,686
Since Chris moved the black box to a more desirable location, there was no need of any manipulation on the dipstck. Only a gental thrust was needed.:baby:
LWATSON
future trans limpers
Jul 30, 2008
2,587
54
Scotland Neck NC
My dipstick is now bent in two places. Although it still looks good and works good would it bring me more pleasure if I had it on the other side?
paint94979
Beer Nazi
Sep 18, 2006
11,714
Yes there was plenty of lube which is why it only required a gental thrust to drive it into position.
Ah I see everytime I try and insert my dipstick in a new tighter location it usually takes me a lot more effort than a gentle thrust. I usually have grab it pretty tight and force it quite hard several times maybe ill try lube next time. Thanks for the heads up gentlemen.
15,686
Would that be a "gentle" thrust or a "genital" thrust.... two very similar solutions to a common problem
I chose to leave the I out of the word for fear of reprimand or possibly worse. :eek: :angel:
I see you were the first one to catch that. :thumb::D
Back on topic.
You are incorrect in your statement as the word gentle is an adjective and genital is a noun. One is a description and the other is a tool.
LBZrcks
Jun 2, 2007
5,297
12
SoCal
All that in under a minute too!:spit::spit:
whitetrash21
Apr 29, 2008
4,929
Vegas
Back on topic.
However both can be used in descriptive form when referring to a "thrust"..... one describes the motion while the other refers to what made the motion....... :D
I caught it simply because im good with a tool..... the callouses prove it :angel:
