DIY lift pump plans anyone?
Kappa9012
MAN.... I Broke it again.
Aug 5, 2008
694
Peoria Il
Can you not run the pumps at full pressure if the ficm is on the supply side? Plus you wouldn't get as much cooling affect if it were on the return side.
blk smoke lb7
<-----Lots of green $
Nov 8, 2010
5,694
59
belvidere,ill
Are you guys cooling the FICM with returning fuel so you can run the pumps at full pressure?
Im cooling the ficm and I have no problem holding rail on my truck.
No you cant if you turn it up over 12 you get a fuel presure to high code.
6541LBZ
Feb 6, 2013
19
havelock, nc
blk smoke lb7, I was wondering if you wouldn't mind emailing me some photos of your setup that your making. I cant get the pictures to load on here thanks to being in Afghanistan. Also if you had to compare it to an airdog or fass system which would you prefer?
