Are you guys cooling the FICM with returning fuel so you can run the pumps at full pressure?
Can you not run the pumps at full pressure if the ficm is on the supply side? Plus you wouldn't get as much cooling affect if it were on the return side.
Im cooling the ficm and I have no problem holding rail on my truck.Are you guys cooling the FICM with returning fuel so you can run the pumps at full pressure?
No you cant if you turn it up over 12 you get a fuel presure to high code.Can you not run the pumps at full pressure if the ficm is on the supply side? Plus you wouldn't get as much cooling affect if it were on the return side.
total noob question but where is FICM located on a lbz?
thanks! i can finally stop lookin for it now lolThere isnt 1 on an lbz they are only on the lb7 and lly.In 06 the control was incorperated into the ECM.
