Deleting factory fan?
DetailsUnlimited
1,264
Benton, Ar
I tow everyday but want to get rid of the fan. Flex lite has one that I think flows 6k cfm so that would work. But can you hook it up to turn on with the factory sensor? I know I would forget if it was manual and by doing this what would be the benefits?
SSchmi5519
LLY Cult Leader
Oct 19, 2008
3,387
Arizona
From what I remember, the electric fans just cant move the amount of air that the OEM unit does. Especially in a towing scenario.
DetailsUnlimited
1,264
Benton, Ar
What does the factory flow? 2-15inch fans flowing 6k cfm sounds like alot! Diesel power mag had a guy in there that had these towing a gooseneck around the fields. So he is creeping around the fields and they seem to work for him what's the difference. Thx
SSchmi5519
LLY Cult Leader
Oct 19, 2008
3,387
Arizona
The OEM clutch fan moves up to ~10,200 CFM.
Rhall
Old Skooler
Aug 12, 2006
2,241
40
Texas Y'all
With Flex Lite you stick a probe into your radiator fwiw
jpowel29
780
Bentonville, Arkansas
I would not want to test the limits of the electric fans especially towing heavy. I have seen several dual electric fan kits come up for sale from guys that have tried them on their tow rigs.
On my truck dual fans and the factory radiator were overkill. Most of the time the fans would not cycle on unless in stop-n-go driving in the summer heat.
SSchmi5519
LLY Cult Leader
Oct 19, 2008
3,387
Arizona
Depends on whether the fan is attempting to engage. Is the time worth it? In my opinion no, or I would do it every time.
13,599
633
This maybe a stupid question but can you just take the fan off for racing or is the extra HP not worth the time?
That stupid behind the fan shroud they put on the 06+ trucks makes it a PITA to get the fan out.
Regardless of whether or not the fan is fully engaged, it is always drawing some power.
turbhoe
researching lbz swap
Jan 8, 2011
141
jacksonville florida
are any of the stock fans electrically clutched or are they mechanical? i ask cause i see a setting for fans temps in hptuners for the lbz. and if so you could just use the clutch signal to run a relay to turn on electric fans.
