I mounted aluminum stock (about 2in wide 1/8th thick- see photos on pg1) on the shaker itself then used threaded rod on each side and one on the front mounted on locations already on the engine. Passenger side i mounted it near the fuel service/test port. Driver side i cannot recall for sure but there should be a location parallel to the passenger side that can be used as a threaded point. The front mount i think i mounted on the metal bracket near the oil filler/fanshroud
