At what rpm does a gt4204 lite staging. What will help most with this turbo to decrease drive pressure?? Headers, or some bd manifolds or something eles
Kurt any pics of the motor rebuild?
You should not have too much trouble staging with a GT4202R if you spend some time tuning it. Only in super-thin air (over 8000' DA) does it require a looser converter.
what ended up being the problem with it?
I am in the process of having my tranny build and i need to no what kinda stall converter to go with for this set up. The motor was put back together with stock parts from now. I checked my drive pressure and @ wot i was running 40 pounds of boost to 95 psi of drive pressure does that seem about right?? My goal with the gt42 is to decrease drive pressure to a 1:1 ratio or close to it. And keep a single cp3 on it
11.99 here i come.
What type of setup did you use to check your drive pressure, IMO, 40 - 95 sounds really high, accelerating the drive pressure will be a little higher than boost, but once in 5th gear it should lay down and be a lot closer than 2-1.
