converting 2wd 6 speed trans to 4wd
DylOrr
101
Kinderhook, IL
I'm purchasing a parts truck that is 2wd, and I am needing to convert the trans to 4wd for my use. I have a spare 5 speed for parts and I was wondering if I can unbolt the tail housing out of the 5 speed with the output shaft and planetary on it and swap it onto the 6 speed. Thanks
THEFERMANATOR
LEGALLY INSANE
Feb 16, 2009
3,890
45
ZEPHYRHILLS, FL
You have to pull the trans, stand it on the bellhousing, then swap them but make sure to check the shimming as theres a shim that goes on the output shaft to adjust rear endplay.
IOWA LLY
Yes, its really me
Feb 23, 2007
2,275
You will need to use a 6 speed planet.
