Yup! Modded stocker from Russell currently. Ported and polished with a batmowheel
Started tear down today. Hood and fenders off, engine harness out and most of the stuff out of the way to start tearing down to the heads. Not bad for 4 hours of work
Any particular reason the pass side accessory bracket and breather/catch can can't be used with the lly stuff?
Hope to have the heads off and protrusion measured tomorrow to go get head gaskets
Why wouldn't I? Works fine as is. Just didn't know if for some odd reason it wouldn't work
Wouldn't be too tough to fab up a bracket that would bolt the lly ficm to the lb7 accessory bracket. That's what I'd do.Well unless your mounting your lly ficm somewhere different no it won't work lol
Sent from my SAMSUNG-SM-G870A using Tapatalk
Dumb question.. But shouldn't you be able to use a magnetic base dial indicator to check protrusion?
That's probably what I'll do. Nothing a welder can't fix
Tried that with my other dial indicator. The readings change every time you move the base after 0ing to the block. I couldn't get a consistent reading and yes, I was measuring off the wrist pin side of the piston lol. It varied as much as .010. I think the mount was flexing or the base just couldn't keep a level spot. With the bridge, you are on two spots across the block and stays more consistent/level. Plus no arms to change height on you.
I see. I was just curious. Figured it would work lol
James protrusion all over the place means pistons and rods are bent and f'kd. Time for fingers!:rofl:
What's that blue marks all over the deck?
