It's DURAMAX inspired at least since it looks nothing like any powerstroke I've ever seen. And it sure aint 6 in a row.
It's DURAMAX inspired at least...
I guess you can call i t a re-engineered Duramax then.
It isn't. Nowhere near.
I disagree
But I disagree with him as I believe it is Dmax inspired knowing the trucks both Curtis and Brian have built and just the fact it doesn't have cummins or ford parts in it.
Utahski apparently knows more about it than me, even though I have had my hands on it but I don't remember all the details so at this point his info may be more accurate.
Like I said, I will be down in Curtis' shop hopefully friday to grab my heads and I will squeeze him for info.
Either way it is an extremely cool build and I hope it blows the doors off the competition.
Elsewhere it was said that the fuel rails are from a Powerstroke. That makes it almost as much Powerstroke as it is Dmax. LOL
Obviously, it's likely the most radical diesel motor sports engine in existence today! It's beyond badass!
And there you have it, it is more DURAMAX than powerstroke, therego DURAMAX inspired.2 CP3's feed an LB7 rail in front. Fuel lines go from there through LB7 valve cover seals to a 6.4 fuel rail on each side and LBZ injectors. The whole thing is just remarkable.
Easy now... Utahski will get upset soon if you keep calling this work of art a shit hole duramax... Though it does use duramax parts, but damn it don't you ever compare and insult this thing with the duramax name.
It sounds to me more like he took the best parts out of a few different engines to make a beast than was inspired by any one engine.
