Brake upgrades
Harbin_22
3,858
Southern Indiana
Crown Performance is the only place I could find that makes them all for 07.5 up trucks. Was a nice kit with all necessary brackets and parts. Little pricey, but a nice kit
c20elephant
C20ELEPHANT
Apr 25, 2013
2,065
Phoenix, Arizona
Crown Performance did not have the lines for the 2001-2006 trucks till I spent some time to give them fitting measurements for the rear lines at the calipers, so I have the first set they made on my truck.
The kit fits like OEM parts with all the brackets like you stated. After replacing the lines I cycled the ABS module several times via a TECH-II and the it stops a 100 times better between the new hydraulic lines and bleeding...
3,581
I wonder why Dylan didnt have those for sale on here along with all the other parts he had?
minerigger
2,660
Casper, WY
Wondering the same thing tom, I bet they would go fast. On this topic of brake I put in a set of the Russell stainless lines and it helped pedal feel alot. Flush the fluid every 2 years regardless of miles. I'd like a 11 hydrobooster and new stainless hardlines to replace all the factory stuff
KyleC4
470
Bay Area
So, when you guys upgrade to the '11 LML hydroboost do you use the your same master cylinder that came with your truck? Or is that changed as well? Cause by GM part number my master cylinder only goes on 01-02 vehicles.
Noreaster
2,910
Cape Cod,MA
I like the reactive one rotors from Napa, their pricey but their really holding up well to the salt environment up here
gmduramax
Shits broke
Jun 12, 2008
4,190
328
Nor cal
I used the factory master on an 04,05,07.5, and 08
c5fourj
Occasionally moving quick
Dec 20, 2014
307
3
Brighton, CO
Do you guys have a part number for the 2011 hydrobooster? Mine just started leaking out if the weep hole.
