Hate to post because it looks bad on my behalf as a tech, throwing pride out the window to get this truck out of my shop..
04 lb7 allison 2wd, previous tow truck..
Problem is : truck came in a couple months back with witing rubbed on the fuel lines, happened to be the twisted pair for the vss or output speed sensor. Repaired with solder less connectors and heat shrink as I do all of my wiring.
Month later truck comes back, same issue as before, only has first and reverse. I pulled the entire trans harness up and checked repaired/ re loomed it all. Put it back together. Same issue.. Checked pins at tcm and tightened a few up that had been wallered by a test light it appeared. Same issue.. Finally got back on the truck today after it sat here two weeks waiting on time.. Put a spare tcm I had on it. Same issue..
I realized today though that in park the speedo will move up to about 10 mph at idle, and oss is about 400-500 on scan tool. When put in drive or reverse it all goes to zero. Drive the truck and it will not shift out of first gear. No codes in tcm, service brake light is on throwing a c0055 vss code.
Am I fighting a trans wiring issue or something in the abs screwing with me and throwing me off?
Just cleaned the abs frame grounds and the connector at the ebcm. About to start looking for other wiring issues after I finish another truck.
Ideas or Input?
Thank you in advance.
Ideas or Input?
