my truck wont hook up and hops in 1st to 3rd BADLY!!!!!!
Caltracs needed?or is there something better?
What tires are you using?
Stock balogny skins for now,Should i wait and see what happens after the tire swap?
got emi ainrt got anything like you do, but spring clamps are cheap and they made a helluva difference. empty or loaded, it plants the tires and HARD..... great for burnouts, and launches.... if it will hook on the stockers.....
You removed some rear springs didnt you? I think with springs removed caltracs are a must to keep things in check in the rear. Aslo i notice with mine that that when i get any hop its usually in the front from the suspension unloading, I want to try new shocks but im to lazy.... Tires IMO help a great deal also.....If they cant spin they wont hop... ubt still to this day my bstg 60' is on stock aluminim wheels and worn out stock tires!!!
Thanks Caleb
yes i did loose some springs and just installing some new torsion keys
I would also like to try some new shocks on the front
Ill keep ya posted after all the mods are done
Wheelhop can only happen if you are spinning one or more tires.
That being said, axle wrap is the true reason for wheel hop. The axle rotates backwards of the drive direction, the tires slip, then BANG! the axle whips back where it was, unloading the tires so they can bite again, then it repeats.
Traction bars will stop axle rotation, but you want good traction too
Isnt it impossible to spin only one tire in 4wd?
Yup, 3 tires cannot be one speed, and one tire be another.
You can spin 2, 3, or 4 tires.
But if you are 2wd, you can spin one.
I have traction bars and clamps if needed.
what kind of traction bars ....got pics
I have pics of my full lengths in my garage because they are off right now. im going to make a shorter set kind of like cal tracs ill get some pics up tonight simon if you get some videos for me:hug:
thanks but there wont be any vids....anytime soon
the caltracs are nice but I always thought longer ones would be nice
