Bad front hub
GeneralTJI
Turbo Todd
Jun 1, 2010
1,272
Colorado
I replaced my front driver side at about 110,000. Didn't really have any noticeable side effects, just happened to check them with it on my lift and it had 1/2" play in it. I'm a little dissapointed that one went out that soon (no lift, big tires etc.) But from the sounds of it a lot of guys don't make it that far :(
Hopefully the rest will last a while... think I paid about $170 for a Timken. Not a bad job, although that tutorial was nice to have!
JMK777
16's, but i keep em clean
Mar 20, 2008
1,433
5
Moss Beach
both of mine went out at around 95k a month apart. not a sound just tire ware and about 1"+ of play when I jacked it up.
battlegraduate09
Gearhead
Mar 18, 2010
610
both of mine are still good somehow. When i put my new wheels and tires on i checked the hubs and that was just maybe 2,000 miles ago.
Kat
Wicked Witch of the West
Aug 2, 2006
17,899
13
60
Norco, CA
Seems different truck have different symptoms. Mike L found Blues the truck shook, Wendy just had a high pitch squeak that drove me nuts, Casper we checked after every LSR pass.
Wendy's where replaced at 35k & 37k. I think it has something to do with my 4wd launches :witch: :driving:
TeaBagger2006
Im a Garrett Nut Swinger
May 11, 2008
3,123
15
Bis ND
i have 146k on mine...no problems....but now that i have these SLIGHTLY bigger tires on her, im gonna check more frquently for a bad hub. so far 2k with the lift
1,674
GMC >> 2003 >> Sierra 2500HD >> 6.6 >> Brake/Wheel Hub >> Axle Bearing and Hub Assy >> 5th one down the list
ecc_33
Junior Member
Aug 10, 2006
1,925
Amanda, Ohio
my pass side hub had about 1 inch of play in it... driver side is as tight as a well you know what
x2 Mine went out at 48,000 miles. Absolutely no sounds or symptoms. I had just drag raced the previous night going over 110 :eek: It was so bad I don't know how the wheel didn't fall off. The funny thing is the tire didn't even lean in like a bad ball joint
DetailsUnlimited
1,264
Benton, Ar
I've noticed my truck pulling while racing in 4wd but nothing else? Jacked both sides up and the driverside was moving couple mm's nothing major. For 99K miles 70k of those with 40x15.50x22 on and the rest towing and drag racing I'd say they did hold up pretty well.
