No you can’t do it remotely.
You would need either an MDI2 or another approved GM tool like a mongoose (~$600).
I’m not horribly familiar with HP on this platform simply because it’s never in the conversations of platforms to use. EFI nor SPA would not have an issue flashing the module.
You can send me the modules and I can reflash them with SPS.
Ok was thinking it was something along those lines. Great service for the money and thank you! It very well may still come down to this.
I was suprisingly able to make contact with the original tuner who did the 5 position efi tunes, waiting to hear back, but he thinks he still has the stock tune from my truck. Didn't think this avenue would pan out, but it might. So that may end up being the easiest way to return to get on with this. Thanks!
If you plug in your HPT, it should tell you what the hardware is. However, it will fail if you try to 'read' it since the OS was changed to accommodate the DSp5. That's how I seem to recall. And don't feel like a dumbass. We all started somewhere!
It gave me some OS numbers when I tried to read the tune, but no serial or anything further. I got a matching OS base file and built my tune from that, but HPT won't flash it to the truck no matter what I do. As usual, HPT was no help.
I have tuned probably 50 cars, trucks, airplanes etc. over the years and somehow have never had to deal with this type of fiasco. Most of my projects use standalone ecus or at least had access to the ECU tunes or the stock tune from said vehicle to start with. I have definitely been lucky that way. This truck is literally built from probably 3-4 different trucks and is no surprise it's throwing some curve balls. I usually am smart enough to stay far away from things that other people have worked on and modified very much...... usually ?
Really do appreciate the help from all you guys on this forum. HPT forum deleted my post, and wasn't helpful through the support system. But here people have taken the time to offer ideas, and solutions, base files etc. Awesome!
Will report back if I am able to obtain the stock tune and get it flashed back on the truck. Fingers crossed.
-Todd
