allison problems P0757
jmar243
07 lbz
Sep 20, 2009
23
pa
can anybody help me out?
these 2 codes come up
P0700 tells the engine transmission is malfunctioning
P0757 soleniod b is stuck on
the computer notices this because there is excess pressure but the soleniod might not be stuck open
i ran the truck hard then drove about 3 miles and let it idle for 10 min and shut it off, is started it up and drove it out the lane and shifted into 3 and the rear tires completely locked up, went back and then went front, kept on going out the driveway, i was coasting down a hill and it was like i put the brakes on then the truck stoped and would not go anymore rev the engine some and it would not go at all but would go in reverse, it was like a valve was slowly leaking pressure into another gear or something
i pulled the valve body off and looked for stuck valves or dirt or anything, everything appears to be ok but i am also not experienced with transmissions
oil looks ok a little dark but not bad
small pieces of clutch material in oil pan but this could be normal to i am not sure
any help would be greatly appreciated:hug:
Mike L.
15,686
232
Fullerton CA
Don't think it's going to be simple if you see clutch material in the pan. Cut the filters open and see what's inside. Could be a short but I doubt it. Maybe a bad pressure switch manifold which is cheap and easy to replace.
I'm betting a valve stuck because of clutch material.
TrentNell
Finally underway !!!!!
Jul 7, 2008
7,543
slc tuah
X2 last time I saw that code and had reverse and no forward gears , the C-1 's were the culprit , but as Mike said drop the pan , cut the filters open and check for clutch material .
jmar243
07 lbz
Sep 20, 2009
23
pa
thanks for the advice
i was just not exactly sure what was going on
Thanks again:thumb::thumb::thumb:
jmar243
07 lbz
Sep 20, 2009
23
pa
What does it do if you put the truck in neutral?
when i put it in neutral it goes into neutral
when i put it into d it does not go but when i put it into r it does go into reverse
So i cleaned the valve body and put it back in
now i can drive it without it locking up the rear tires
when i put it in D it engages hard
R engages har
but the second gear shift there is a big defuel and then it slams second
3rd is normal
4th is a little more aggressive than normal but not bad
5th is good
6th is good
when it goes to lock tc if i am hard on the throttle it locks properly, but if i am going lets say 51.1,51.2,51.3 etc. anotherwords very light on throttle it engages dissengages engages it is like it is not sure if it should lock or not
any suggestions on how to fix this would be greatly appreciated Thanks
MACKIN
Smell My Finger...
Aug 14, 2006
3,948
Connecticut
It's toast. If it's locking up the rear wheels then the clutches are hung up as the steels are warped and there is no clearance.
Order your parts or find a builder
jmar243
07 lbz
Sep 20, 2009
23
pa
it does not lock up the rear wheels anymore though since i cleaned the valve body
13,599
633
Sounds like you have some problems. I would be pulling the trans and checking clutch packs. The activity shown in your avatar isn't helping your trans any.
jmar243
07 lbz
Sep 20, 2009
23
pa
the truck was hooked to a sled 11 times this summer, and did about 5 drag runs
does that make it time for a refresh?
13,599
633
No, but your problems make it time to at least look at it. Something is definitely not right.
mack attack
Oct 3, 2010
9
maine
Hey Jmar243 I am having the exact same problem. When the truck shifts into 2nd the rear tires lock right up. and when its on the lift it looks like the accually start turning backwards!!! I just rebuilt trans and put it together so all the clutches and frictions are good with good clearance. Did you find your problem??
jmar243
07 lbz
Sep 20, 2009
23
pa
sorry for the late reply lol
there was a lot of dirt in the pan, c3 clutches needed replaced and the valves were hanging up, also the torque converter was on its way out, clutch material was pouring out of there as well
