FIRST, sorry about the two threads. Hopefully a mod will join them for me.
Yes, the stock brakes seem to last the longest. After that, no luck. I buy med grade pads from the parts house. The high end ones tend to be too hard and brake dust builds up or they squeal so I go for middle grade. There's only one option of quality for rotors at the parts stores around here.
I suppose I could put all stock parts on from GM?
I've done all the filing/sanding and test fitting the pads first to be sure they slide free but not so much they can get uneven & bind. I've tried anti-seive to try and keep the pad frame from rusting and sticking on the little sheet metal caps that come with the pads that go on the caliper lip. I've polished that sheet metal cap until it's like a mirror. I make sure the slide rods that go through the caliper are clean, rust free, smooth, and packed with grease when going back together.
IDK what else to try? There was a really good thread on DP about this with a super knowledgable guy (or so he seemed to me anyways) and don't see where he says to do anything more than I have to ensure good brake life.
This current set has plenty of pad life & rotor left but they did the uneven wear thing so the rotors are likely ruined.
Guess I might try some aftermarket rotors and/or pads but I feel this is more an issue with the caliper not applying evenly? And I have no idea what would cause the brake pads to wear like they have. I remember reading back when I first was looking to buy a dmax truck, someone mentioned this was common deal with the GM brakes since the mid-90s I think??
Oh well. Just frustrating. This set might have 50K miles? I'd have to check my records.
