The accesory drive arrangement, obd1 to obd2 were the primary differences. All the pmds are the same, just make sure it has the resistor installed in it before you plug it in.
If you look inside the connector on the pmd itself you should see a little circuit board. You can attempt to pull the old one out or just buy new they are cheap enough. If buying new get a #9.
