Done 2 of these dmax swaps and well if you want some ideas on how I pulled it of feel free to email me. [email protected]
The engine looks way to high in the frame. I used round urethane bushings from http://www.ruffstuffspecialties.com/catalog/LSMOUNT.html like the Merchant engine mounts and fabbed my own dom tube X Member. The wiring is cake to make stand alone. You will need some electrical knowledge and use some diodes to get your 71 ignition switch to do what a dmax wants it do to. Use the blazer/Suburban fuel tank and cut open the top use epoxy and screws to fasten the dmax sender base into the blazer tank. I have pix somewhere it works tits. You can use the dmax rad core support and all the rads and coolers. Use a Fass 150/150 w filters or the like. get EFI live youl need it. the wiring is actually simple. I did ABS, cruise control, a/c, factory dmax alarm, power windows w van regs and my mods of which I have templates around, used 72 tilt colum and crusie lever, My dash is all stock 72 stuff minus gauges.
First one was 1972 4x4 blazer This next one is 1971 c10 on c30 frame w AAM rear, Dana 60 HP ford front, Next one is going to be a 71-72 Crewcab custom built cab.
Love the project so far.
Good grief, you need some "build" threads my man!! I'd love to see the ones you've done so far!
