66 fuel pressure pump leaking
1,732
Need more information. Did you prime it? Is it building any pressure? Walk us through what you have done so far. We can guess all day but it would be much easier for you to just tell us what you've done
1,600
Merged your two threads and moved it all to the LMM section.
As 2004 asks, we need far more info than what you've posted. We dont have a crystal ball to see what you did.
Lovsey
Aug 21, 2020
Replace the fuel pressure pump ran for about 50 miles then just stopped running it is getting adequate pressure to run just not sure why it is not
4,873
Yeah... if you can’t explain further than what you are saying, your best to take it to an experienced mechanic.
Nothing you said gives us any ideas. We can’t work miracles off the little text you gave
ZeroGravity58
1,382
46
Maryland
I'm gonna shoot in the dark but maybe you got a bad cp3. Check your actual and desired rail pressure when cranking.
Lovsey
Aug 21, 2020
Well I'm not the mechanic thought maybe you guys were I knew more about it at fix my
self
Lovsey
Aug 21, 2020
And it is in a shop and they don't know what's wrong with it paid them 4000 fuel pressure pump on ran 50 miles quit running. Towed it back to them they don't know what's wrong
1,732
You need to take it to another mechanic
They should be checking the actual pressure and desired pressure. Return on the pump, pressure relief and each injector. Replace any out of spec. If everything is within spec then it is not the fuel system and possibly something else like cam or crank sensors, electrical, etc
Does it smoke at all? Proper cranking RPM? A good mechanic should know all this. Get your money back and take it elsewhere. Let us know where you are located. Maybe we have recommendations for a good shop near you
Lovsey
Aug 21, 2020
Thank you very much I live in Edwardsville Illinois shop that it is in it's alJets I guess they're a bunch of dumbasses they are in Staunton Illinois
