4th Gear Pulling
clrussell
pro-procrastinator
Sep 23, 2013
5,910
364
Buddy used to pull 4th locked with 4.56s and 35s.. Then went to 285s..
Truck was probably around 700hp
ecc_33
Junior Member
Aug 10, 2006
1,925
Amanda, Ohio
IMHO you would be better off with 3rd gear and 35" tires with that gear ratio. I pulled with 4.56 gears with around 700hp and in 4th gear still had to unlock the converter at the end. This was on very tight ohio clay tracks. I tried 33" tires with same results. Not enough HP's plain and simple.
