400,000 Miles After 17 Years – Your long term reviews?
Mile_high
The Mad Hatter
Oct 31, 2009
716
Denver, Colorado
Sup, nerds?
Last week my 2001 Silverado 2500HD rolled over 400,000 miles.
I bought it in high school, paid cash for it the day I got it, and I've owned it for almost 17 years now. It's still my daily driver and my work truck, so it doesn't get babied.
DD has always been an incredible technical resource, so I figured this would be a good time to ask the guys who have been keeping these trucks alive forever:
What modifications have actually stood the test of time? What isn't worth the money? What have you found that improves on the factory design? What's easier to service? What have you done that you'd absolutely do again?
Thanks to everyone who's contributed over the years. I've probably spent hundreds of hours reading this forum. A lot of what I've done to this truck—and a lot of mistakes I probably avoided—came directly from information posted here.
The Truck​
  • 2001 Silverado 2500HD 4WD
  • Extended Cab Short Bed LS (Leather, Power driver and passenger seats, Side airbags, Center console / CD rack thing)
Dealer records showed the injectors and CP3 were replaced just shy of 100,000 miles. I bought it with around 150,000.
It needed a transfer case almost immediately (pump rub). We swapped in a low-mile takeout from a wrecked truck, and I rebuilt that transfer case again recently.
Around 180,000 miles it got a lift pump, EFI Live, and a built Allison all at once. That was an awakening, as you all know.
That combination has been so good I've just driven the wheels off it. Sometime in there it hung an injector open and needed a head gasket, so I stepped up to 45% SACs but surfaced the head and went back with head bolts. Maybe that was a mistake; 5-6 years later it knocked the head gasket out again so I went back with ARP studs and fleece heads here recently.
Current Setup​
  • Stock air box and stock-style filter
  • Stock turbo
  • Stock CP3
  • Stock exhaust with the muffler replaced by a straight section
  • Lift pump
  • EFI Live
  • Built trans
  • Fleece heads
  • ARP studs
  • 45% SAC injectors
  • Eaton Truetrac rear differential
  • 2006 PY0 wheels
  • FICM kill switch
  • Jimmy Jammer door reinforcement plates (because Denver...)
  • Bluetooth conversion in the factory CD radio
Here's My Question...​
The lift pump, tune, and built transmission were worth every penny.
But now I find myself wondering if I've become the old guy who says, "Eh, it works fine."
Am I wrong by still running the stock air box, stock turbo, stock CP3, and basically stock exhaust? When I had the heads off, labor was essentially free to throw a turbo or CP3 at it, and I just...didn't.
The truck pulls hard, tows great, starts every time, and I've never really felt like I was lacking power when I hook onto a trailer.
I've looked at compounds plenty of times and always come to the same conclusion: "Man...that's a lot of money."
Then again, I'll probably end up talking myself into buying a set of those 6-lug Wherli PY0 wheels for my half-ton, so maybe I'm not the best judge of financial decisions.
If this were your truck sitting at 400,000 miles, what would you do next?
  • What's the best modification you've made that most people overlook?
  • Anything on my truck you'd have done differently?
  • Any upgrade you regret?
  • Is there something obvious I'm overlooking?
Looking forward to hearing what everyone thinks. Thanks, dudes.
PureHybrid
Isuzu Shakes IT
Feb 15, 2012
3,923
823
Central OH
With those miles, I would've done a cp3 with the heads off.
For me, transmission was the best upgrade with Marks tunes right there with it. Only thing I regret was being cheap and doing a fingerstick when I was dirt poor instead of a tune. That and injectors, years ago I put a new stock set in. Definitely should've gone larger, but it was a daily driver at the time
8,223
Not a damn thing I’d change other than throwing a cp3 at it. What you have is what i consider “just right” before the price per 1hp gain starts to get out of hand.
Dont get me wrong. I love the shit out of my built engine/compounds and big injectors but it cost a fuck ton more too. Youre in the sweet spot
WVRigrat05
3,146
37
French Creek, West Virginia
You definitely were smart by not making it a ticking time bomb, I personally would have probably done an intake and a 4" exhaust, but obviously that isn't necessary from the sounds of it.
I personally can't leave anything alone and have never owned anything I haven't had to had the motor or trans apart well before 100k mark. So sounds like what you're doing is working.
3,143
How do you like the Truetrac? How does it work in reverse? I've always thought about getting one. Maybe one up front too if they are available.
3,559
You are exactly where you need to be. Fast, streetable, usable power. Anything more and the reliability of your truck will start to diminish.
My setup was about the same except I had Rick Lance's exhaust manifolds and uppipes, hogged out turbo horn and a Silverline 4" exhaust.
Fleece wasnt yet making heads back then.
As James said, only thing really missing is a CP3, but if your stocker is fine, leave it.
chevyburnout1
Fixing it till it breaks
Aug 25, 2008
2,374
9
Berthoud, CO
God I miss my stock truck :LOL: Just remember you'll become that old man some day with that truck and be super thankful you kept it the way you did. Sounds like one solid running truck!
Mile_high
The Mad Hatter
Oct 31, 2009
716
Denver, Colorado
Great. Fine in reverse; same issues forward and back, just low speed soft stuff without dragging the brakes it will rock. Deep gravel and soft dirt only at low wheel speed. Pavement is a dead hook; in the turn under power drives great.
I blew up the rear on my half ton and put one in. Loved it so much I put one in the Duramax before it needed one. Open diff is for the birds after feeling that thing bite down on the road.
Dozerboy
5,100
702
TX of course
If you’re happy with the truck, there’s no reason to change anything.
I bought my 06 new and I’m just now adding compound turbos. I’ve been just enjoying my truck and adding power as I felt the need too. If it was my daily I would never to as far as I have. My truck has 220k on it and with the power I’m making I’m definitely playing with fire.
