2013 Duramax Allisons Shift patterns in Tow Mode
LizzieCBK15
Jun 1, 2016
We recently purchased this 2013 Duramax CC/LB DRW to replace our 2001 Chevy 8.1 with Allisons.
We towed our trailer (5th wheel weighing 14,000# verified) this past week through Mountains in PA on Turnpike and Rt 79 from RT 70 in MD. Everything was great. Better towing than the 2001. Same trailer was towed by previous truck. My question is the shift patterns with this Allisons (Diesel) versus our Previous Allisons (Gas 8.1). Much better pulling up long climbs. Less down shifting which was pleasant! Couple of times I applied more pedal, during a climb, the down shift appeared a little more harsh than the previous vehicle. Both in Tow Haul mode. Is this normal? I know in Tow Haul mode the shifts are more pronounced to prevent slippage. Up mountains trans temp never went above 153 with Ambient temp 85. Level driving trans temp was around 140.
duratothemax
<--- slippery roads
Aug 28, 2006
7,139
12
Wyoming
Was it particularly noticeable on the 6-5 downshift?
If so, its a known issue, and GM came out with a TCM software update to correct the harsh downshift...as far as I know, its not "bad" for the trans, just annoying for the driver. Your GM dealer can reflash it for you, they'll probably charge an hours' worth of labor.
LizzieCBK15
Jun 1, 2016
Yes I assumed it was downshift from 6 to 5. Though I've seen postings that state when in Tow Mode transmission doesn't go into 6th gear. I looked for any TSB's for the 2013 year and didn't see any. I see a lot of folks had reflashing done for earlier models.
Mike L.
15,681
236
Fullerton CA
Since I had my TCM replaced, it no longer clunks on a downshift. Upshifts are much better.
