I have read the threads about the trans heating up and at this point I am wondering if I may actually have an internal issue. This truck has 150K on it and has just gone down the freeway most of the time but about a dozen times towed a 12.5K 5th wheel for a month a year also. I know how to drive it and have always used tow mode plus manual and not pushed it up hills. It has always run hot from day 1 and even in cooler ambient temperatures. All stock except I made braided lines to replace the rubber cooling hoses. When it gets hot almost nothing will cool it down except idling. Down hills higher rpm, no good. In fact it seems to even get hot when trying to use the higher rpms to brake downhill. By hot I mean just shy of the red. A few time I have it go into showing the temp was overheated and I stopped. I have changed the fluid twice, never dropped the pan and change the external filter every 10k. I use Transynd. So now I am wondering what to do next? I won't take it out next summer unless I have a plan to fix it and have that done first. TIA for replies.
