2001 4.8L dual-tank OS
3,681
236
My friend and I swapped a 2001 4.8L into his old 1984 Ford pickup, which has dual tanks. I would like to get the GM ECU controlling them, but I can't seem to find a 2001 OS that supports dual tanks.
His current OS is 12208322, so if someone has that with dual tanks, I can segment swap, but I could just copy/paste the tune over to a different OS if necessary. It is running the stock 2001 GM dashboard, so probably best to stick to 2001-2002 tunes.
Anyone have one laying around, or know where to look for one? It seems all the old tune depots have shut down (holdencrazy, etc) :(
THEFERMANATOR
LEGALLY INSANE
Feb 16, 2009
3,890
ZEPHYRHILLS, FL
3,681
236
The suburban with dual tanks runs the transfer pump to move fuel from the rear to the front. Your best bet is going to be to find a 6.0l dual tank tune from a 3500 cab and chassis pickup.
That's actually what we want to happen. We plumbed the main high pressure fuel pump and return into the front tank, and a transfer pump from the rear to the front tank. I managed to locate a 2001 suburban tune, I'll see if it works.
Sent from my E5823 using Tapatalk
THEFERMANATOR
LEGALLY INSANE
Feb 16, 2009
3,890
ZEPHYRHILLS, FL
The pickups and burbs both work the same way transferring fuel forward. The only difference is the suburban used 1 filler hose for both tanks while the pickups used a seperate filler for each tank. Since they worked that way, the suburban tune is not as picky about seeing the fuel transfer at a specific rate, so it is alot more foregiving.
