1055 or precision sled puller
Sledheadxp800r
That was only my tow tune
Dec 13, 2010
1,151
41
I'm in need for a high stall converter for this pulling season. Any reason one is better than the other?
Sledheadxp800r
Dec 13, 2010
1,151
41
I went on the diesel performance converters website to check it out. There's really not much info on it. Ill have to call and see what they have.
bullfrogjohnson
Big Girl!
Nov 20, 2006
4,167
41
Locust, NC
I have run both the 1055 and the precision. I got rid of the 1055 for the sled puller. The sled puller will stall higher but seems to be hit and miss on the lockups. Never had that issue with the 1055. I would look into the 1053 also from suncoast as its looser that the 1055.
I really like the precision and it does what I want. I think suncoast makes a better converter but their customer service and price of repairs suck ass! These loose converters will have to be refreshed often and when it costs 400.00 at suncoast compared to 150.00 at precision it makes the choice a little easier.
05smoker
I'm officially done!
Mar 30, 2007
2,379
Lebanon, OH
I've run a 1055 and now a 1053 on my 2.6. 1053 all the way between those.
I have no experience with the Precision converters.
DeMax LB7
Bowtie Child
Dec 11, 2011
155
Rice Lake,WI
So travis are you saying you like the 1055 better or the sled puller? i understand the cost in all but your saying the lock up is hit and miss???
dmax06
barely getting by......
May 10, 2009
262
white plains, GA
X2 on Diesel Performance Converters. Talk to David (DTS) about them, I'm pretty sure they are the only converters he uses... just my .02 :thumb:
ecc_33
Junior Member
Aug 10, 2006
1,925
40
Amanda, Ohio
I believe camomax runs one of there converters ( DTS, Diesel performance converters) I know Matt loves that converter. Says its by far the best one hes ran yet.
bullfrogjohnson
Big Girl!
Nov 20, 2006
4,167
41
Locust, NC
I loved the 1055 converter. But I had reached a point in turbo size that I needed more stall that what I could get out of it. At the time the precision sledpuller was the only converter that would stall higher than the 1055 other than custom ATS units. I dont like ATS trans parts so I went with the Precision.
I like both of the converters. It all comes down to what size turbo you want to run.
The downside to really loose converters is that when stalling on the line the input and output speeds are so far apart that when you come out of the hole the turbine cant catch up with the impeller and the tcm wont request lock up.
You can use a lockup controller to fix this but the really loose converters tend to have a shorter lifespan in general.
Sledheadxp800r
Dec 13, 2010
1,151
41
Lockup shouldn't be a problem for me because I'll be running another one of Bens lockup controllers on my puller. Unless the TTC tends to burn out quicker from locking up with greater Input and output rpm differential.
