Awesome.. This is helping me narrow down to the actual injectors I need to order. I'll have to spend some time searching for a thread/how to on replacing them to make sure I don't need any specialty tools. From what I have seen it looks like you just need to remove some of the hoses and stuff up top (similar to the 5.3 liter knock sensors) and then take off the valve covers.. but having never actually done it.. I am sure there will be some tool that is required and/or super handy that just makes life easier.
Is there a brand that is best? In my research leading up to me finding this forum I kept seeing BOSCH everywhere.. but tons of people warning of "fake" BOSCH as well.. Or is there a reputable site to order from? @Bdsankey had mentioned sending me a message with some info.. Haven't seen one come yet (to be fair.. it hasn't been that long)
Thank you for sharing your knowledge base.. I have far less anxiety now about spending $2k or so on injectors than I did yesterday. Much appreciated![]()
It's a fairly involved job, but there's really not anything that difficult about it. I'm a decent DIY mechanic, and I didn't really have any trouble at all. Took a weekend, and that included plenty of beer drinking time.
The was only two "difficult" (more like 'tedious') parts of the job:
1. Scraping the gasket material off of the valve cover. Just very tedious.
2. Cleaning up the injector cup seats in the head (basically removing the old Loctite material so you have a good sealing surface). I used a brass tube brush attached to a drill, which worked fairly well, but was still difficult to get to and see what you're doing.
As far as special tools, the ones I can think of:
- Metric crowfoot flare wrench set (for the injector lines); they're either 17mm or 19mm, I forget. Link
- Injector puller. Some say you can use a prybar, but I found the tool to work nicely. Link
- A good set of hex keys. Both socket drive and L-shaped. Square ends for breaking loose, ball tips for getting the screws out the rest of the way.
- Decent torque wrench.
There's good arguments both ways regarding pulling and resealing the cups or not. But for me, there's no way I'd spend that much time and money, and NOT go ahead and reseal all the cups. If you do pull the cups, you'll need:
- Cup puller. Worked great, though I do think I had to find a larger washer than what came with the tool. Link
- Loctite for resealing the cups. LOTS of people have used the 272 Loctite (red, high temp thread locker) for many years without issue, but I used the 620 Loctite (green, high temp retaining compound) because it's stronger and designed specifically for this purpose. But, it's up to you and the 620 will probably cost a few bucks more. Link
- As described above, some way to clean the old Loctite off. Brass pipe brushes, etc. I also pulled my glow plugs and jerry-rigged an air line into the cylinder to keep positive pressure on it to keep debris out (though it probably doesn't matter much).
- New set of cup o-rings (ask whoever you buy the injectors from about these)
As mentioned above, there's good reason to replace the high pressure lines now also, as they're likely rusted and in not-great shape. That said, they're pretty expensive and many people clean and reuse them. Mine were terribly rusted, but I still decided to reuse them. The key is to not mechanically clean them (i.e. brushing, sanding, polishing, etc.), because that will damage the sealing surface. I stuck mine in an ultrasonic cleaner with a chemical called EvapoRust. Lemme tell you: that stuff is magical. They came out looking about 98% as good as brand new, and I've no issues with the lines thus far (~15k miles later).
