Lost trans cooler line while driving.
mechman3
no such thing as too fast
Jan 7, 2015
185
Saratoga Springs, Utah
I have a 2005 GMC CCLB, MikeL rebuilt my trans about 5-6 years ago. I was on a long road trip empty. I never noticed the trans temp above 204F. I tend to check often. Some where between Las Vegas and Saint George I started loosing trans fluid from the connector at the radiator(lower line). The trans obviously did not care for that. I pulled into a hotel for the night , barely. I added 3 quarts in the morning and the trans would not go into gear. I had it towed to a trans place. When they finally looked into it they determined the connection was bad repaired it added 11 quarts of fluid and test drove. Initially the trans was not happy but as they drove the shifts became more and more smooth with the only hiccup being the lockup converter but it was getting better. What would you guys suggest I do now? I have been driving it for about 2 months now and it does not seem any different than before.
3,148
I'd try resetting the TAPs first. Maybe it was trying to adapt to the lack of pressure and the TAPs reached its limits and now it's way off. It may slowly works it's way back but the 5 speeds are a slow learner. Might be a good idea to change the spin on filter too in case you got any additional shedding pf clutch material in there
Also keep the fluid level on the lower end of full as these transmissions tend to act funny when full or over filled
