Bought a Cruze
3,574
That's why there are oil catch cans available for these cars, if you choose to go that route.
1,514
Ordered the zz performance oil can kit, got the easy part on..
Oil catch cans are fairly basic.. hold probably a pint, has straight thread O-ring fittings boxes that are bigger than -6 and smaller than -8.
Got road trip tomorrow to pick up stuff that's been on wish list for my square body.
1,514
Well that was eventful 350 miles... Get about 100 miles from home getting on the freeway, threw 0299(underboost) misfire #3, U0100-71 loss of comms with ECM, service stabilitrac and traction control. Got random flashing check engine light (probably related to misfire)
Under 3000rpm it misses, above runs smooth. Swapped plugs #1/#3, code stayed stuck on #3.
Not quite sure what to make of this color of oil in the catch can.. see what it looks like tomorrow after all the air is out
Part of me says coolant mix but usually that's more white than creamy/carmel color
1,514
A lot of catch cans look like that from what I’ve seen. It’s oil and condensation essentially
Thought I mentioned it, gues I didnt...
probably 200 miles was in rain or extremely humid to the point AC condensed water on the windshield while running 70-75. Which could be a logical explanation
jlawles2
1,126
66
Danbury, TX
As long as the oil on the dipstick does not look like that and the coolant levels are not changing, I would attribute it to something else.
Surprised that the oil and water did not separate out. I've see the chocolate milkshake in person before and even then it surprised me it did not separate out.
1,514
Well ordered zz performance ignition coil and boost kit.. definitely starts revs misses substantially smoother.
Pulled plugs ran a compression test.. 1/2/4 are 190-200psi #3 is goose eggs
This is fun🙄
1,673
I lost an injector working on my LLY last night. At least my buddy took one from one of his trucks to fix the issue. I think I may have to replace them all.
Really whish I could LBZ swap this bad boy.
