If I were you I'd look into S&S
Some of us locals have issues as well. I don't have anything II on my truck but I watched an 85% pump grenade on the dyno at Edge before on a local guys truck.
HSP is a dealer. It's all I would use knowing what I know now.
It's worth the call for sure
thanks for the info I do have a used 120% II (12mm stoker) pump for sale![]()
Are you not going the II pump route anymore cayden?
Lbz, built trans, efi by Danville, Danville 68, full egr delete, mbrp down pipe, 5" mbrp to 7" stack, ppe guages, custom traction bars, airdog2 165, ppe fuel rail mods, s&b, afe blade runner, Arp head studs..died March 2015
Parts collected for the build. SoCal super damper, SoCal billet flex plate, SDP S400 kit, II 85% CP3, PPE manifolds/up pipes, PCV reroute. Slowly but surely lol
ImTheir "cobra" injectors are nothing special anyways. :roflmao:
Why would you say that?
Because I'm not a nut swinger fanboy.
Oh lol thought you had some actual evidence.
I called up to II and actually talked with them today I wanted to actually see what they had to say about grenaded cp3's and what not, they basically said that there injectors where all 100 Bosch and they are certified by Bosch all there equipment is Bosch ect ect, also there Remans are all 100% remained all new Bosch parts ect. They said there is stuff they mod not these pumps that others don't. Said that most companies put a stroker crank in pump and that's all and that they do other things and that's why there cp3's can flow more than competition. Now mind you I'm not defending them so before anyone tries to verbally chop off my end please realize I'm posting this to put out what I was told today. Now I will also add that they did not answer my question as to what was going on with pumps exploding and bad injectors, I asked that question several times and I was never given a direct answer just told more about what they do. They also said that if you ever have a prob with there products u can send it back and as long as it wasn't caused by contaminated fuel or something not the fault of the product they will take care of you. Again not defending them also not against them pretty indifferent. Just putting out there what I was told
