D-MAX Mafia
Hood down, smoke up!
Nov 4, 2009
1,112
13
Phoenix
That rear suspension is the cats ass. Man that rig looks killer
Thank you! It's for sale!
Nightmare!!! How she running?
Really good with the new Danville tuning @markbroviak . It's been sitting for quite some time so there was a lot that needed to be addressed. I finally got the old man to sell the damn thing! Mostly because every rubber diesel line was leaking, it had some electrical gremlins, all 4 windows cable gears broke, tires were dry rotted and the paint was all but shot. Also it hadn't been registered in 2 years.
Needless to say I took over ownership without too much of a fight!
Fixed everything and changed up the look a bit.
'06 '07 LBZ's
Owner of ShopSource.com
& Evil Arc Fabrication
Canigetanamen
Dec 12, 2015
Swapped out my ball joint rod ends for heims.
"Don't sweat the petty things and don't pet the sweaty things"
aldenrichie
106
Covington, TN
Finally got my Fass 150 installed as well as the Bean's sump. I can notice it runs a lot smooher at idle now as well as when I romp on it! Very pleased with it all!
Sent from my SM-N910P using Tapatalk
dmax_ty
479
Utah
Top pick is at Discount going under the knife; bottom is the after shot.
Rubbed like a bugger on the stock suspension, but is a little better now with the t-bars cranked up. Still need to shim the bumper and possibly trim a touch. Very happy with the look though.
1,514
Work today consisted of oil change, new rear brake pads and new caliper guide bolts at just under 290,000 miles.
Bought 33' of 3/16 steel brake line 14" -3 DOT braided line and -3 to 3/8"-24 adapters and rubber line clamps to swap out the 29' long 1/8" brake hose on my Kauffman trailer.. Should allow quicker apply/release/response of the disc brakes. Weather got shitty yesterday after i got loaded.. Most likely be swapping everything out at a later date
WolfLMM
Making Chips
Nov 21, 2006
4,005
26
AL
Magnaflow 3 inch downpipe, what a bitch to install on the LMM. Can't really tell much if any difference either. All part of the big recipe though!
1,514
The joys of idler pulley failure..
And not an effin squeak out of it either..
$145.00, new belt, two new smooth pulleys, and the tensioner pulley all replaced in a local Napa know how parking lot.. Can't do that with a big truck..
And for losing power steering/brakeing... These EoH Kodiak 13" disc stopped the whole unit without effective truck brake like no big deal on manual application :D
8,237
Replaced my brothers radiator yesterday on his '10 lmm and installed an s&b intake on it. It may be getting a delete, blocker plate, Transgo jr, and tunes soon hehe :D
aldenrichie
106
Covington, TN
Took the wind-flector deals off of all four doors yesterday to replace with in-channel versions. Another one of the reasons I took the old ones off was because the drivers deflector was not the same style as the other and had some "goop" holding it on. The other 3 removed pretty easily but the drivers one brought some paint with it . That adhesive the previous owner used was no joke! Looks like I've got my weekend project lined out
