Can't see em that good on my phone you may be right. Maybe he will tell us
Easy guys. Lets not be so childish. Just because it isn't what you, or most of us here, would do, isn't a reason to insult the guy. To answer your question, most tire rubbing problems aren't caused by clearance with the inside edge of the tire on our trucks. They are caused by the outer edge of the tire rubbing the fender at the back of the wheel well opening or the bumper. Using a wheel/tire combo that sticks out further will cause more of a clearance/rubbing problem in most cases.
.......To answer your question, most tire rubbing problems aren't caused by clearance with the inside edge of the tire on our trucks. They are caused by the outer edge of the tire rubbing the fender at the back of the wheel well opening or the bumper. Using a wheel/tire combo that sticks out further will cause more of a clearance/rubbing problem in most cases.
Picture missing for me.
Anyone else notice that the members who acted like this was Duramax Forum all joined post-2010, and the three from pre-2010 actually gave info to help the kid?
And you guys wonder why I bitch all the time that this forum has gone to shit. Whole lot of you need to grow the hell up.
O/P, Josh and Dale are right. Wider the "stance", the more the tires will rub. Might want to look into putting a 4" lift on the truck...then you can run what you want.
For reference, I run a 325/60/18 on a 0 offset 18x9. I'm not cranked fully (fender to hub 24.75"), but did a fair amount of trimming on the bumper and only had to tie back the liner in the rear. You'd most likely be into the metal on the bumper for a Chevy.
Your results may vary.
Just remember the more negative the higher the chance of rubbing.
Fwiw I fit a 305/50/20 tire and didn't have to do a single bit of trimming at all but the wheels are around a +20 or +0
That's only half the dimension, what about backspace.?
This can't be accurate, you're running LML wheels with a different lug pattern with adaptors/spacers
