Yeah probably. Mine would do that cold occasionally and then work if I turned it off and back on.
It's really not that bad, unless you have a drw.
So i lost the lift pump last night bypassed it... Shut the truck off to pull timing to fix little timing rattle.. Truck lost prime had to use either to start it..Now this...
https://youtu.be/2aktTH6gIpE
Disconnected cp2 rail goes to 13,000 at idle vs 1200
you suuuuuurrrreeee you have no restriction with no lift pump running?
Codes are cleared.. Still can maintain rail pressure.. Thus "easy shit" sucks
Idk if there is actually a problem or I'm sucking air from some hole that didn't leak with a working lift pump![]()
oh thats right, forgot you did all that. that bleed screws uses an o-ring though dont it?
No o-rings.. Oem unit was leaking no one had a good one local so I did this... Everything hose clamp and AN firing is tight
Did full ecm reflash, truck started then lost prime.. Huffed some either in now rail is +/-100 psi of command and it will driver through the brakes..
who know wtf happens.. Could be as simple as a air pocket.. Idk I got no manual what to prime it...
To prime the fuel system or find a leak?Are you able to use air pressure in the filler neck?
Not at back corner of a truck stop..
Won't work unless you remove the return fuel line and cap the tank side only of where that line goes. Or open the system somewhere after the filter if your just trying to prime the filter.To prime. I would use some clear hose to isolate the air leak without the lift pump.
