Truck is an 07 classic ccsb 4x4 195K miles, lift pump, efi live with idaho rob tuning, 450whp ish, 33" tires, no lift. I had my trans built back in 2010 (@100k) by Mike L. It's got a suncoast kit, and mikes converter, plus whatever tricks he does. Everything has worked great for the last 100k miles. I daily drive, tow often but usually under 10k, and I go through rear tires quickly.
Now in the last week or so i had a couple shifts that missed, revving up, then banging into gear while driving casually, it did it a couple more times, and then wouldn't shift out of 1st. Then the tires locked up, had to drive in reverse to get it to free up, and then limped in 1st a couple miles home.
CEL is on, codes p0700, p0757, and p2724. Fluid is at the bottom of the hot hashmark when warm, looks clean, and i change the spin on every oil change. Trans usually runs below 210, above 150 depending on temp and how i'm driving. Has hit 230 towing up fireroads last summer.
I read up a little bit on it and sounds like i may have chunks of clutch material lodged in the valve body causing some selenoids to stick.
Is it salvagable or time for another rebuild? Will i be able to save any money since it's already built, or is it the same as starting with a stock trans?
