MBRP 5" Drone
Dec 2, 2006
1,696
TN
I've got a 5" Exhaust on my LML, and it has a pretty good drone to it when pulling an incline. Anyone have any recommendations for a resonator or different muffler to quite it down some?
TeaBagger2006
Im a Garrett Nut Swinger
May 11, 2008
3,123
15
Bis ND
A down pipe should help with the drone. Mbrp sells an ultra quiet muffler that's above their normal mufflers.
N2BRK
2,377
712
Fte resonator mounted as far forward as possible will cure the drone
kiwilml
454
The resonator is best thing to fix it.. I think a 5" just has more of a drone, I personally don't have a resonator but I do have a muffler and a bigger down pipe and mine is still loud..
My brother has 4" and his was definitely quieter then mine and then he put in a Banks muffler behind his mbrp and it's really quiet now, so that'd be an option also, to just add another muffler..
$chultz38
230
Look into Donalson or Nelson mufflers. My LML is aftermarket downpipe then 4" Flo Pro delete pipes with a Nelson 42" straight through muffler and it sounds stock. I like the stealthily concept so I left the stock tailpipe and def tank in place. Both companies make straight through resonators also. The muffler I put on was $90 so the price is right too.
Dallas S
496
Alberta
I have had great results running flopro twister mufflers as resonators. A twister mounted up stream of the stander flopro mufflers really cuts the cummins drone down, should work great on the Dmax too
13,862
966
This is a 4" exhaust, but I installed this Donaldson muffler along with a flopro twister muffler for a customer last week who wanted a quiet exhaust. It was very quiet.
$chultz38
230
Looks alot like my truck. Can't imagine how quiter it would be with the twister also. I was going to use a Nelson resonator also but changed my mind.
ujtruck
May 7, 2016
I deleted everything, at the moment running straight pipe, loud
do you have part number for donalson or Nelson, and where can i order ?
want stealthily concept and stock kinda sound. I'm in Canada
Thank you
NinjaMax
WTF!
Oct 3, 2012
1,266
Severance, Colorado
This is the one ill be getting if the drone ever gets to me. From all my googling it sounds like you'll keep all the "other sound" but lose the drone. But like these guys are saying, I'm sure they all work.
