first off i have a 2006 lbz has 206k all stock execpt k&n intake on it havent had it very long was great at first now having weird problems
it all started one night (was cold but not sure that makes a difference) went to start and thrown a code lost communication with trans .. i reset and seemed to drive just fine .. went a couple days and figured it was just something weird going on... well a few days later it did it again but still drove just fine
about a week after that started seeing voltage codes along with the original codes
today went to start it and it went to start and stalled .. tryed again and did same thing .. put my foot on and gas pedal and started right up throwing alot of codes
figured maybe its a weak battery and got them load tested and seemed weak so i went and bought some nice agm batterys for it and still same thing and it doesnt matter if its out side or in the bay 65 degrees its now doing it every other time trying to start
thought perhaps i had a bad ground
tested at the battery for voltage and had 12.3 resting then checked at fuse block and only have 11.5 with no load i did find a bad ground and fixed thatnow at the fuses i see the same as at the batterys but problem is still their and im not sure where to start now i will post a bunch of pics of all the codes
thank you in advance for any help
