1,456
Sounds tight, Adam:thumb:
What tunnel was that?
Thanks
One of the Lehigh tunnels on I70/76 in Central PA
This is a 2-3 mile 5% just east of breezwood PA on same road.. Which was taken before the tunnel
https://youtu.be/rk0xS95974Q
>dreaming< I want to twin the GT4088R with GT4202R sure Dan could work something out with their 40/42 twin kit
Some 60% injectors .. Need rods before I do that lol
coldLBZ
Apr 22, 2007
2,344
40
Alberta, Canada
Yes I installed everything. It wasn't horrible, but it could have been better. The lines were bent pretty close but not perfect, so it took some re-bending to get everything to bolt up. You have to pull the box to put the main rear line in and the front right side line is a bit fun to put in. I would pull all the lines out intact so you can get a feel for how to put them back in. I do recommend pulling the drivers seat out to put the hydro boost in, made my life a lot easier.
Thanks. Hopefully pulling the box isn't too bad, I've never done it.
Henry95
283
What I got to work on today. Makes my truck look small.
Aug 3, 2013
898
Arizona
I havent been on here for an age!! Anyways, I sold my lb7, then bought a 2010 mitsubishi ralliart the next day. 13 days later I get rear ended and the car is totalled.. I might get an lbz next, we'll see. Having that car was super fun, but if I was in my truck when I got rear ended, none of this insurance headache would have happened and I'd still be driving my vehicle the same day. Crazy joojoo
Sitting on side of road... Transfer case when into neutral.. Parking paw grinds when going from gear to park..
:mad:
Cost me $1000.00 quick money :mad:
Crawl under tht biotch and pull the encoder and manually put it in a gear with a pair of pliers
3,421
New FPR and Tstats yesterday. Its been so long I havent had a smooth idle that I completely forgot what it sounded like. Not kidding.
Truck actually gets up to temp now, too.
Overall, a productive 4 hours or so.
Today was AC compressor pulley bearing and new valve cover gaskets/plugs on my son's 01 Aurora 3.5. Gawddamn car has a miss now, so tomorrow get the tech2 out and find the reason. Must not have connected a spark plug correctly. I havent worked on a gas engine in forever. I had to remember where my feeler gauges were to check sp gap.
Harbin_22
3,858
Southern Indiana
Put some 5" magna flow SS exhaust on, and went back to a single 72mmstg2RR since I sold my twins. Man I can't believe how loud it is. Been years with twins.
3,421
Yep...springs inside boots on rear bank werent making contact. Why couldnt it have been the front bank? :roflmao:
