rgullett83
1,607
Illinois
Turbo swap with my assistant
1,457
Always find the positive
4.56 gears are working out nicely.. Still working on remaping the fuel/timing tables since load hits the tables differently anything much more then 61-62 mph temps just start climbing.. This is 5th gear on a slight incline and I'm in power band enough I can pull 90% of the hills without downshifting or slowing down more then 5mph
8'8" tall 96" wide 24' long 14,000lbs putts me at ~30,000lbs gross
1,457
Engine will be out in 3 months anyways
Oooo damn that's low brian
Or abouts.. Swapping a LBZ/LMM block in so I can get the lower bracket for fan cowling back on...
With the trash compactor truck heated up faster and took longer to cool off in 60° weather... Going to be much worse come summer
coldLBZ
Apr 22, 2007
2,344
40
Alberta, Canada
X2,
After all new stainless hard and flex brake lines, lml hydro boost, and new tires, go to get it aligned and they said time for new front end parts.....so next up is a ultimate idler arm, and rare parts pitman arm and tie rods.
Did you install all the brake parts yourself? How was that? Any tips? I'm going to be doing pretty much the exact same on mine.
Finally lowered the rear of my truck the rest of the way. Pulled over loads and the medium spring in the pack.
Finally sits level
