My block had main studs in it when my first crank broke. Reused that block and haven't had any trouble in 10k miles and its been set on kill since this engine went in
Mine has lasted 10k with many 1,000+HP beatings and is all good. Hit and miss maybe. Maybe your block was junk to begin with.
No problems with you Jason. Well, I may give you some shit if you go through 25 engines and haven't learned anything :rofl:
I'm sure it would be warranty IF you never tuned it as that's low miles for any sort of failure. Depending on what the coverage is of course. But they need to do all the diagnosis and subsequent repair if warranty for you to be covered. Coming in with a box full of parts will likely result in a polite go pound sand.And yes, it is a crank failure, right in front of(?) the #1 main
Block looked perfect, the rings hadn't even fully seated yet on that GM re-man.
Yes, I could fight the warranty process, but there is a specific way you have to do that and a drawn out time frame to get it done...
At best, I'm going to take the crank to GM and see what they'll do, I don't jump thru hoops well and even tho it was a significant "chunk of change" some things aren't worth the headache...
Believe me, I will make my thoughts clear and my opinions well heard and very known. I have a long standing relationship with the dealer I purchased the block from. Unfortunately, the final decision doesn't rest in their capacity to make, and like I said, I don't jump through hoops well...so Im just gonna have to play it out and see what happens.
I did document a portion of the tear down, but Im sure GM would've wanted to investigate critical aspects as it was tore down. I doubt I'll get much more than a "sorry, we would've liked to help"
Any idea on price?Wagler has billet cranks in stock ready to go!
https://m.facebook.com/WaglerCompet..../1051787614866708/?type=3&source=54&refid=17
Any idea on price?
