Hey Mike - LML / 2015 Trans questions
Djreversal
72
well I wouldn't be doing the tuning.. I was more curious about shift points and things like that. I know my LMM was a nice difference when they changed the transmission mapping.
Mike L.
Got Sheep?
15,681
Fullerton CA
The LML has the best strategy yet as far as pressure. They use it where it's needed, not all the time like earlier models.
S Phinney
4,008
Quncy, Fl
I see the name is a line pressure upgrade kit then. Is it worth doing without doing a full build for a tuned deleted daily driver?
Djreversal
72
I don't have a choice but a full build at this point.. but I just wanted to see if they ever got into the tuning of it for like raise rev shifts or quicker shifts or whatever.
Mike L.
Got Sheep?
15,681
Fullerton CA
Trans has to come out for this mod. Pump has to be dis-assembled. Converter clutch may not like the higher pressure as it can break the lining off.
Ben's pressure mod works well instead as it is all electronic.
S Phinney
4,008
Quncy, Fl
So you at minimum should replace the convertor if you do this?
Djreversal
72
i think hes saying the way he does it with modifying the pump and all the whole trans is coming apart so u might as well just do it while your in there.. if your going to do the pump mod and the torque converter your already more then half the cost I'm sure.. might as well just put the clutch kit in there to.
