LLY: New DD 05' regular cab 2wd
duramaxzak
Wanna be puller!
Nov 22, 2008
2,431
14
Minnesota
[/URL][/IMG]
3,590
Zak your only lying to yourself. We all know it will be slammed with drag radials and built motor this winter lol
Yup. May as well use quick-release pins to hold engine/trans in the pulling truck, as it'll now be doing double duty.
The lure of the RC/LB is strong....
:hehe:
duramaxzak
Wanna be puller!
Nov 22, 2008
2,431
14
Minnesota
Is it possible to get the Y-bridge back together with out removing it? Although if I remove it, I will probably weld it together so I don't have to worry about it again.
minerigger
2,660
Casper, WY
Yea. You can weasel a pry bar down in there and work it until it goes in but you'll obviously have to be super care full not to cut 1 or both of the o rings. Pull it, clean it up, weld it
Max Attitude
814
Middleville, MI
Anybody looking to do a EGR delete, spend the extra money and get a good kit! I bought one off Amazon that looks just like a Sinister kit and the bracket on the new intake tube does not line up right. I just left them bolts out for now and went for a test ride and blew the Y-bridge out!!! I will have to modify the bracket so I can bolt it down and help hold the Y-bridge together.
Sounds like a kit a friend of mine put on. Same thing with his. Was the brand CTS or something like that?
duramaxzak
Wanna be puller!
Nov 22, 2008
2,431
14
Minnesota
I got the Y-bridge back together and modified the mounting bracket on the delete tube. Took for a test drive and it seems to be holding so far.
duramaxzak
Wanna be puller!
Nov 22, 2008
2,431
14
Minnesota
My HSP 2-piece Y-bridge and cold side pipe showed up yesterday! I ordered them in the bare finish.
[/URL][/IMG]
[/URL][/IMG]
11B_DMax
Oct 5, 2015
50
33
Fort Bliss
" I swear hun this is the last thing im buying for the truck, promise"
2 weeks later " i dont know where the cadillac went.... but look at this new turbo!"
looks like a real clean truck. fleet trucks are usually a safe bet to buy even with high miles
SteveLBZ06
Jan 6, 2013
200
Central MA
It's amazing how handy those lift gates can be. We bought a truck that just happened to come with one at my work and we use it all the time. Truck pretty much doubles as a fork truck around the shop
duramaxzak
Wanna be puller!
Nov 22, 2008
2,431
14
Minnesota
Installed some Bilstein shocks on it today. I think the shocks I removed were the original's with 300k on them!
Still haven't install the HSP Y-bridge yet!:eek:
