holyshitbatman
holyshitbatman
Mar 17, 2015
123
Albuquerque new mexico
So my tcase turned out to have the case hole someone jb welded over it and filled it with oil and called it done. smh!! So i dropped it main shaft is toast pump and forks all all jacked and pretty sure the chain has slack athough i have yet to find a way to measure the chain well anyway being im not the richest i start poking around for parts to rebuild it myself i find a used tcase on ebay get it for 140 i figured if anything i could use the housing off of it.so it came in i ripped her open amd happy surprise only thing wrong with it is the pump died theres no rub hole shaft and bearings have no play i have to have used up all my luck for the year :woott: now just waiting on a new pump and pump rub kit and seals to get here and ill be back on the road :thumb:
Deleted another Lml this morning using some more tunes from Tony.
MAXX IT OUT
Neglected
Mar 1, 2013
1,791
Des Moines, Iowa
Built my load helper and finish putting my sump and fuel system back together.
frankenstien
587
Fairbanks,Alaska
Finally got a chance to work on my truck.
Cognito UCA's, new lower ball joints, replwced both front leaking axle seals, bilstein 5100's all the way around, torsion keys, mickey thompson sidebiter 2's wrapped in 295/75/16 toyo open country AT2's.
I have offically taken all the chrome off it, its black enough to make batman jealous
Also added a basic fass lift pump a couple weeks ago.
baddaddition
Mar 10, 2013
287
Getting closer... She says when I make the connection ,,, that'll be my expression.... Didn't really understand it..loluploadfromtaptalk1446350590873.jpg
Sent from my XT1254 using Tapatalk
baddaddition
Mar 10, 2013
287
Anyone? Joe Gibbs? Is that like burning the bible? Lol well I have 110$ worth of it now...
baddaddition
Mar 10, 2013
287
1,514
Really wish the Dmax was under the hood vs over the rear axle..
cdbright
JUST RENT IT
Dec 16, 2008
1,016
Salt Lake City, UT
fixed the screwed up pin on my DPS 5 switch so it would not jump from tune to tune, now it is just stuck on Race permanently, and also installed the rail pressure gauge that Auto meter replaced for free and it does exact same thing, if wired correctly as a 2009 it surges the truck makes her knock, if i wire it like a 2008 it pegs at 30K and stays there, total fail all around. :mad::mad::mad::mad:
baddaddition
Mar 10, 2013
287
Made brackets to hook to seat belt mounting.points plus wrapped a strap around engine and back seat support.. To secure the engine...
These old cars never really had a high crash test ratings...engine moving is least of my worries in a wreck.
Lmao!!! That is too good!! What we do to keep the our trucks Alive!!
