Out of curiosity, does the LML tuning have the same power increases over stock as previous generations? Cuz doesnt the LML make like 100 more HP than an LBZ? So, if you can get a +230whp built trans tune on and LML that's like 330hp on an LBZ....right???
I believe my tunes are 60,120,150,200. I guess that's why the instructions say not to run the last two tunes without a liftpump, because the cp4 might not hold up?
Your tunes are probably 60/90/110/130-150
Unless you have a built transmission
Lift pumps start being required around 90-110 over stock
So Kory, with the cp3 conersion, a turbo and a built trans, the stock LML will push 700...like an LBZ is "good for" 600???:baby:
So dose a lift pump help prolong the cp4? I'm a little scared to run any higher tunes. Don't want to damage anything.
Really! That's pretty impressive. Now the tuning bridge has been crossed it seems like the LML'S are proving to be quite the beast of an engine!Man honestly without a lift pump and maxing out the regulator in tuning we can generally hold close to 150hp over stock. The cp3 conversion and injectors will generally give up 700hp, sometimes a little more and sometimes a little less as long as the supporting air is there.
Do you think the second tow/eco tune is safe to tow heavy with? 10,000lbs or more.
