1,456
Hauled my brother MCLB 6.7 lost wheel u joint
Robby05
Jul 25, 2014
498
Spokane, WA
Finally swapped the OEM minivan size tie rods with a set of rare parts G2's. Tomorrow's project is to swap pitman, idler & support
OregonDMAX
NOT IN OREGON, NO DURAMAX
Apr 28, 2013
3,964
Goodyear, AZ
Finally had to replace my 10 year old optima batteries. Got a set of acdelco agm batteries and now my truck starts so fast I'm afraid the starter is going to blow the motor up :D
minerigger
2,660
Casper, WY
Nice. I'm trying to sell mine... needs to be 4-6" narrower so I can put my tonneau cover on and open the box lid
Robby05
Jul 25, 2014
498
Spokane, WA
Swapped idler, support & pitman arm today. Man it's nice to have tight steering again.
Weird thing is (I'm not a front end specialist) is my pitman arm came off with little to no effort. I bought snap on's pitman arm puller but didn't have to use it. I was pushing the dust seal up the shaft to make room for the puller & pryed a little on the arm & the Damn thing just fell off. The nut was tight as hell coming off.
Did I just get lucky or was there an issue with the original pitman arm. Truck has 160k & I've owned it for the last 50k.
Awenta
4,090
See anything wrong with the arm? I think you're really lucky.
hdrolling
Freedom Defender
May 11, 2011
61
Fayetteville, NC
Hmm, I've always had to use a lot of force even with the puller.
Robby05
Jul 25, 2014
498
Spokane, WA
Nothing looked out of place. I set the new one in place and tightened the nut a little. Had to use the puller to get the new arm off the steering box. I replaced the tie rods & idler assembly one night & drove truck. Steering was better but still loose. Replaced the pitman tonight & it was night & day difference. Weird...just happy it's tight again
